JoyCart
Lastic
Has thanked: 65 times
Been thanked: 94 times
JoyCart
Beitrag von Lastic »
ArSoft.netstrefa.pl oder Larek hatt ein Arcade-type joystick vorgestellt auf sein Youtube Kanal
https://www.youtube.com/watch?v=62XXBEoS9tM
Via Kleine adapter cartridges die mann hinten einfuhrt kan mann also der layout/buttons compatibel machen fur verschiedene 8/16 bit-machine.
Currently, JoyCart supports the following hardware platforms:
Atari 8-bit / Atari ST / E / Atari VCS / 2600
standard: directions + 1 fire button
Atari 8-bit 2B +
extended standard: directions + 3 fire buttons
Atari 7800
standard: directions + 2 fire buttons
Commodore 64
Commodore 64 3 Buttons
ZX Spectrum
standard Kempston: directions + 3 fire buttons
ZX Spectrum 128k +2/3
standard Sinclair: directions + 1 fire button
Amstrad CPC
standard Joy 1: directions + 2 fire buttons
MSX
Amiga
TI-99 / 4A
SEGA Master System
Mehr Info auch hier :
(Polisch)
www.arsoft.netstrefa.pl/joycart.htm
(Google Umsetzung nach Englisch)
https://www-arsoft-netstrefa-pl.transla ... r_pto=wapp
Preis hab ich noch nicht gefunden, aber wann dass nicht so wahnsinnig teuer ist , wird ich mir ein kaufen.
Blogsite www.thecell.ar
lasticppc@gmail.com
Lastic
Re: JoyCart
Das Antwort dass ich bekommen hab uber den Preis.
Hi.
Thank you for your interest in Joycart.
Unfortunately, at the moment, the entire supply of joysticks has already found their buyers.
I put the order on the waiting list. I will let you know as soon as they are available.
Cable length about 1.5 m.
The current price of the joystick is PLN 325.00.
The price includes three cartridges freely chosen from the list available (the list is available at https://arsoft.netstrefa.pl/joycart.htm).
Each additional cartridge costs PLN 15.00.
Shipping cost (InPost parcel locker or Polish Post) in Poland: PLN 18.00.
Shipping outside Poland after prior cost arrangement.
Unfortunately, I cannot guarantee that the price will be kept in the next series.
Kind regards,
Arkadiusz Lubaszka
larek
Umgerechnet 325 PLN = 67 EUR.
lasticppc@gmail.com
Been thanked: 41 times
Re: JoyCart
Ich verstehe die Problematik hier nicht so ganz!
Geht es hier um einen Joypad für einen 8bit Computer (Atari XL)? Sowas läßt sich doch aus einem Joypad für PC und unter Vorhandensein eines Joystickkabel leicht selber herstellen. Man muß nur den inneren Aufbau kennen. Dazu hänge ich Dir mal den Auszug zur Joystick-Modifikation zu Moon-Patrol aus dem Magazin 140 an:
Joysticj Mod.png (133.15 KiB) 5066 mal betrachtet
Die Button 2 und 3 solltest Du dabei bitte übersehen!
Ich habe einen solchen Umbau mal an einem solchen Gamepad vorgenommen (hoffentlich läßt sich das Bild darstellen), von denen ich 2 Stück für je ~10€ kaufte:
Ich mußte dazu leider auch ein paar Leiterbahnen vom Lötstopplack befreien und Kabel direkt auf die Leiterbahnen löten. Leider arbeitete das Ding nachher nicht präzise genug und wanderte schnell in eine Bastelkiste.
Ein Testprogramm läßt sich auch sehr leicht in BASIC schreiben:
10 PRINT STICK(0),STRIG(0):GOTO 10
Der "PRINT"-Befehl kann durch das "?" abgekürzt werden ...
Diese zeile reicht und kann mit der Break-Taste abgebrochern werden. Hoch/Vorwärts gibt den Wert "1", Runter Wert "2", Links Wert "4" und Rechts Wert 8 aus, Ruhestellung (nicht ganz sicher) "0" oder "15". Der Wert der Feuertaste ist "0"" für nicht gedrückt und "1" oder "-1" für gedrückt.
Dinadan
Has thanked: 370 times
Been thanked: 104 times
Re: JoyCart
Beitrag von Dinadan »
Burkhard hat geschrieben:
25.10.2022 11:33
Kein Problem, sondern eine schlaue Lösung. Schau mal das Video, auch ohne polnisch zu können versteht man das Konzept. Der vorgestellte Arcade-Stick lässt sich durch wechselbare Adapterkarten für die verschiedensten Systeme umkonfigurieren. Ich werde mir das Teil vermutlich mit den Karten für Atari Joy2B+, Amiga und Sega vorbestellen.
Re: JoyCart
Dinadan hat geschrieben:
25.10.2022 13:31
Kein Problem, ...
Je nachdem! Wenn man sich das Teil in Polen ordern muß wohl auch 'ne Kostenfrage, da der Versand aus Polen viel höher berechnet wird als innerhalb Deutschland. Dazu käme noch das entsprechende Gamepad, wenn man -wie ich - nicht über eine entsprechende Konsole verfügt!
Hier noch ein Bild des von mir umgelötteten Pads:
Re: JoyCart
Bei mir lassen sich die aus dem Netz gesuchten und verlinkten Bilder nicht darstellen - Ist das eine Einstellungssache oder gewollt?
Has thanked: 362 times
Been thanked: 913 times
Re: JoyCart
26.10.2022 10:17
Hallo Burkhard,
das ist gewollt. Alle Inhalte muessen vom ABBUC Server kommen und koennen nicht extern eingebunden werden. Das hat mehere Gruende:
1) extern eingebunene Inhalten koennen ein Sicherheitsproblem sein (oder werden), da wir keine Kontrolle ueber diese Inhalte haben
2) extern eingebundene Inhalte koennen mit der Zeit verschwinden
3) die Rechtslage ist beim Einbinden in die ABBUC Seiten nicht klar und kann fuer den ABBUC zu Rechteverletzungen fuehren
4) die IP-Adresse und ggf. Cookies des Browser werden bei extern verlinkten Inhalten an den externen Server gesendet, dies ist ein Privatsphaere-Problem
Also besser Inhalte (Bilder, Texte) herunterladen und hier neu einstellen.
Beste Gruesse
Carsten
Lastic
Re: JoyCart
Habe grade von Larek e-mail entfangen.
Currently, the cost of Joycart with 3 cartridges = PLN 340.00 / ~70,00€
Each additional cartridge = PLN 15.00 / ~3,00€
Shipping to Belgium = PLN 62.00 / ~13,00€
lasticppc@gmail.com
