ST-Maus
Schorsch
Has thanked: 4 times
Been thanked: 4 times
ST-Maus
Beitrag von Schorsch »
Hallo
Existieren denn außer dem Supergame "Break It reloaded'22" noch weitere Spiele,die mit der ST-Maus gesteuert werden können?
Das ist sowas von komfortabel
Has thanked: 1228 times
Been thanked: 2042 times
Re: ST-Maus
Schorsch hat geschrieben:
20.01.2023 11:39
Hallo
Hi Schorsch,
"Charlie Chaplin" und "atarixle" hatten in der 8-Bit FAQ mal aufgelistet, was mit der ST-Maus am XL/XE alles läuft:
Contributors: Andreas Magenheimer, Mirko Sobe
Title Keystroke Required
- Missile Command by Atari CTRL-T
- Slime by Synapse [T]
- Shanghai by Activision choose controller type: ST mouse ! (plug it into port 2; if you do not have one, you have to reboot!!)
- Bombdown by Roemer of Uno choose between Joystick, Amiga mouse, ST mouse or CX85 numeric keypad (use port 2 for any mice)
- Minesweeper by Raindorf-Soft use an ST mouse in port 2
- The Brundles by KE-Soft use an ST mouse in port 2
- The Brundles Editor by KE-Soft, PD use an ST mouse in port 2
- Geisterschloss by KE-Soft, PD choose Lightgun (port 1) or ST mouse (port 2)
- Vanish (ZONG, Vol. 5+6/1993); use an ST-mouse in port 2
- Hong Kong (ZONG, Vol. 5+6/1993); use an ST-mouse in port 2
- Maus-DOS (ZONG 5+6/1993); use an ST-mouse in port 2
- Faecher-Patience (ZONG 1/1993); use an ST-mouse in port 2
- Macao (Zong 5+6/1994); use an ST-mouse in port 2
- Multi-Mouse manager (PD) drivers for mice, TB, etc.
- Multiplayer 2.1 by Madteam supports ST + Amiga mouse in port A
- Unriagh I (german PD adventure) has drivers for ST mouse+Joystick (stick=port 1, mouse=port2)
- Unriagh II (german PD adventure) has drivers for ST mouse+joystick (stick=port 1, mouse=port 2)
- little Calculator (AMC-Verlag, PD) uses ST-mouse only (port 2)
- big UPN calculator (PD) uses ST mouse, TB, Touch tab. and joystick; (there are different COM files, rename the one you wish to use to *.EXE; all drivers use port 1 - if I remember correctly)
- Operation Blood (ANG/Mirage) press mouse fire or Select to start in ST mouse mode (port 2)
- Operation Blood 2 / Special Forces press mouse fire or Select to start (ANG/Mirage) in ST mouse mode
- Sprint XL (ABBUC Jahresgabe 1992) uses an ST mouse in port 2
- M.O.S. (ABBUC magazine) uses an ST mouse in port 2
- Diamond GOS (Reeve software) all three versions support an ST mouse in port 2
- S.A.M. (Power per Post) german GUI, supports an ST mouse in port 2
- G.O.E. (TCS) supports an ST mouse in port 1
- BOSS-X (MS-Software, Mirko Sobe) supports ST-Mouse in Port 2
Aber da ist sicher in der Zwischenzeit noch eine Menge mehr dazu gekommen....
Has thanked: 329 times
Re: ST-Maus
Zu ST-Mäusen (am XL) hätte ich auch eine Frage: klick
