TNFS Client (nicht Server!) für Windows/macOS?
JAC!
Has thanked: 168 times
Been thanked: 177 times
Beitrag von JAC! »
Hallo zusammen,
gibt's es sowas? Googlen hat erst mal nichts gebracht.
Viele Grüße, Peter.
JAC!
Re: TNFS Client (nicht Server!) für Windows/macOS?
Beitrag von JAC! »
A Linux file system driver which appears to be written in Python? I don't have too much experience with both. Do you think this can somehow be sued on Windows/macOS?
tschak909
Has thanked: 5 times
Been thanked: 203 times
Beitrag von tschak909 »
There is a FUSE driver, yes, but there is also a stand-alone client (the tnfs_client.py) too.
-Thom
JAC!
Beitrag von JAC! »
C:\jac\system\WWW\Tools\TNFS\TNFSClient>python tnfs_client.py
File "C:\jac\system\WWW\Tools\TNFS\TNFSClient\tnfs_client.py", line 101
raise ValueError, "Wire data isn't for this command"
SyntaxError: invalid syntax
I assume 12 years since the last updates somehow makes it incompatible with
Python 3.9.13 (tags/v3.9.13:6de2ca5, May 17 2022, 16:36:42) [MSC v.1929 64 bit (AMD64)] on win32
Has thanked: 353 times
Been thanked: 884 times
JAC! hat geschrieben:
25.12.2023 21:10
Yes, your Python is too new, as the code is Python2 (not Python3) code.
In Python 2, not everything required a function call syntax, like the "print" command
print "Hello World"
In Python 3, everything has to be a function call, so the "print()" syntax is
print ("Hello World")
The tnfs_client.py code does contain "python 2" style statements, so you need to find a python 2 interpreter for your OS.
Another telling sign is the new of the (unix) interpreter found in the first line, it references "/usr/bin/python", which is usually the Python 2 interpreter, while Python3 would be "/usr/bin/python3"
Oh the joy of incompatible software upgrades :)
Greetings
Carsten
Has thanked: 916 times
Been thanked: 478 times
25.12.2023 21:10
Probier's mal damit:
tnfscl.zip
(8.35 KiB) 191-mal heruntergeladen
JAC!
Beitrag von JAC! »
Excellent, that one works out of the box. Do you have a link for reference where it's from?
Dinadan
Has thanked: 362 times
Been thanked: 101 times
Beitrag von Dinadan »
# Copyright (c) 2012 Radu Cristescu
# Adapted to Python 3 by Thomas Meyer in 2022
26.12.2023 00:40
https://github.com/FujiNetWIFI/spectran ... ree/master
