SAVO + Sophia2 = YPrPb
Has thanked: 974 times
Been thanked: 599 times
Piotr D. Kaczorowski hat hier auf AtariAge geschrieben das man demnächst in der Kombination von SAVO und Sophia 2 das Component Video (also YPrPb) Signal nutzen kann. Es wird dafür einen Satz geben, in dem sich befinden:
- Eine SAVO Version (XL, XE, XEGS oder 1200XL)
- Ein Kabel um Sophia und SAVO zu verbinden
- Ein Sega Saturn Kabel (6x Cinch)
pancio
Has thanked: 303 times
Been thanked: 306 times
Re: SAVO + Sophia2 = YPrPb
Beitrag von pancio »
That's very good news but... unfortunately Piotr said something similar many times and still nothing happened!
Moreover, it's not YPrPb but analog RGB on his schematic. Let's see some example before buy it.
pancio
https://systemembedded.eu
PTODT / A.B.B.U.C. Member
Has thanked: 573 times
Been thanked: 511 times
Moin!
Ich dachte das besondere an der Sophia2 ist, dass das Bild digital ausgegeben wird. Nun doch analog?
Dann wäre doch die VBXE sinnvoller, oder was übersehe ich?
pancio
I read deeper and it's possible use YPrPb on the same Sophia2 pins... but there is not so many TV/MONITORS which can coopetare with YPrPb.
If you want to use this solution you need:
1. Sophia2 ~80euro
2. Special expensive 6-RCA cable ~40euro
3. Savo. ~30euro
Little expensive and still no audio...
If you have Sophia2 there is no needs to use YPrPb because you may use HDMI/DVI - it's much better solution I suppose.
@Kveldulfur - maybe try this: viewtopic.php?f=3&t=2819&p=23076#p23076
pancio
