I'm looking for a 1200XL MMU CO60609 or a GAL version of it if someone can program it.
Thanks,
Erez
1200XL MMU
- Sleeπ
- Has thanked: 329 times
- Been thanked: 605 times
Re: 1200XL MMU
if you can burn yourself, I have files to offer (PLD & JED).
I could burn a GAL for you, but unfortunately I don't own a 1200XL so I can't test it for function.
It would be helpful to know to which country a programmed chip should go (because of the postage).
Good luck,
Good luck,
- Dateianhänge
- 1200XL MMU.zip
- (1.44 KiB) 159-mal heruntergeladen
- Has thanked: 1044 times
- Been thanked: 316 times
Re: 1200XL MMU
Hi.
You can have my MMU. My 1200 was rebuilt by Jürgen TTFH and the MMU is left over.
