Von Mad Pascal gibt es ein Update mit zahlreichen Beispielroutinen...
(Text aus dem AA Forum)
new updated version of examples
https://gitlab.com/bocianu/madstrap
Simple Atari Mad-Pascal common project bootstrap.
Designed to speed up project development startup, providing starting set of useful optional features:
two startup files start_os for OS dependent application and start_nos for ful RAM access
memory layout defined in separate file (memory.inc)
constants defined in separate file (const.inc)
type definitions in separate file (types.inc)
external resource loading (RMT, ASM, strings)
external library path definition (blibs as default)
custom user defined charset loading
player missile graphics initialized and used
user defined display list in separate file (dlist.asm)
custom vertical blank interrupt
custom display list interrupt
interrupt routines declared in separate file (interrupts.inc)
utils folder with useful tools and scripts
example $defines
example $EVAL tables
packed folder with useful batch tools generating packed assets from png files (packed/rebuild.sh)
example bash scripts for image conversions and APL/ZX compression (assetes/rebuild.sh)
example batch file for executable building (build.bat)
example intro.pas merged as INIT block (set ADDINTRO=0 in build.bat to disable)
.vscode example settings
Mad Pascal Update mit Beispielroutinen...
- CharlieChaplin
- Has thanked: 357 times
- Been thanked: 417 times
