Hi all,
first I apologize for not be able to write in German.
I've started porting the latest Atari800 core into Atari800MacX and posted it on Atariage - https://forums.atariage.com/topic/38289 ... ri800macx/
In case you haven't seen there, I just uploaded a beta 2 with some fixes:
- FujiNet Boot Priority - Disk drivers take priority over NetSIO/Fujinet (it seems correct, but I haven't had time to test this in depth)
- Using NetSIO term instead of Fujinet in the Settings
- Universal binary (Apple/Intel)
- Speed Limiting Toggle Fix
- Custom ROMs problem fixed
- Default Window size increased
Known problems:
- By default the windows is not properly entered - resizing it a bit will fix it
There are probably a lot of small problems so please keep reporting.
Download:
https://drive.google.com/file/d/1uCiH-- ... sp=sharing
Adding Fujinet support to Atari800MacX
