ich möchte in diesem Thread gerne die Liste der ABBUC Mitglieder im PLATO System von IRATA.ONLINE sammeln.
Ich bin dort erreichbar als
cs/atari
(Benutzer "cs" in der Gruppe "atari")
PLATO könnt ihr vom Atari mit FujiNet, aber auch vom PC/Mac/Linux/xBSD, und auch vom Amiga/AtariST/MS-DOS/C64/Speccy ... erreichen
Erst immer als guest/guest ausprobieren, und dann, wenn es gefällt (und man ein wenig Erfahrung mit dem System hat), unter https://irata.online/ einen Account anfragen.
Man sieht sich im PLATO
Carsten
ABBUC Mitglieder im PLATO System (IRATA.ONLINE)
tschak909
- Has thanked: 5 times
- Been thanked: 204 times
Re: ABBUC Mitglieder im PLATO System (IRATA.ONLINE)
Glad to see you there!
I am on as thomas cherryhomes / atari
There is decades worth of history inside the PLATO system, many catacombs, especially if you get an author sign-on and can type the name of any lesson in the system, as well as use the development environment.
-Thom
-Thom
- cas
- Has thanked: 354 times
- Been thanked: 887 times
PLATO is a fascinating technology. I'm currently reading the book about PLATO ("The friendly organge glow" http://friendlyorangeglow.com/). I will need some time to grasp the system.tschak909 hat geschrieben: ↑27.02.2022 19:15Glad to see you there!
There is decades worth of history inside the PLATO system, many catacombs, especially if you get an author sign-on and can type the name of any lesson in the system, as well as use the development environment. :)
-Thom
@Thom: thanks for making this experience possible
tschak909
You're most welcome.
That is a fantastic book. It took Brian over a decade to write it (mostly due to the scheer amount of research that had to be pulled together).
I was a user of PLATO contemperaneously, as a small kid, and it was an amazing system. I was glad when CYBER1 came online, and got to use the system again. When Tom Hunter and the Cyber1 team pulled together enough tapes to make a functioning system, I asked for a copy, and built IRATA with the purpose that it would be for all the retrocomputer users.
as an aside: There are roughly two dozen different ports of PLATOTERM to different platforms.
-Thom
-Thom
