is there a way to swap one drive against another without performing new mounts?
It would be great if that was possible.
For example shift-ctrl-2 and then shift-ctrl-7 should swap the mounted images, the one from D2 to D7 and the one from D7 to D2.
Kind regards, Erhard
Free drive swap in menu
- Has thanked: 163 times
- Been thanked: 433 times
Hi Thom,
Swapping drives with shortcuts would be a lot faster than performing new mounts, wouldn't it?
Of course this should not be limited to swapping D2 with D7 but any drive against any other.
Trying to swap against itself should / could terminate the swap procedure so one can abort without swapping.
Kind regards,
well, on the Atari, when the FujiNet menu is either booted from the device or maybe loaded from some tool disk.
Kind regards,
